It is currently Sun Aug 10, 2025 10:58 pm
PostPosted: Mon Mar 05, 2018 10:08 am
First name: Peter
Last Name: Norman
City: Grand Falls-Windsor
State: NL
Zip/Postal Code: A2A2V6
I was thicknessing a top for my newest build this morning. Was planning on using Yellow Cedar for this one but noticed two fractures starting to form running with the grain about an inch from the center line on each side of the sound board. They run for approx. 1.5 inches from the tail bock towards the soundhole. I don't think the crack is all the way through the top, but when flexing the soundboard, noticed it open up. It opens when the top is flex downward, in the same way it will be radiussed.
The YC seemed to be quite a nice top, fine grain and perfectly quartered and stiff, with no apparent run out and has been sitting for about 5 years waiting to be used. I've never worked with YC before, so not sure if it is prone to cracking, and if this is something to be aware of when working with this wood?
I've already installed the rosette, and was planning on bracing this evening, not too far ahead, but don't really want to throw away the top, but also don't want regrets after the guitar is completed. I've wicked thin CA glue into the cracks and have seemed to stabilize for now and once braced will place a cleat in the area of the crack.
I'm thinking that there may be a soft grain in there and wondering if this will open down the road once the guitar is strung up and played ?
PostPosted: Mon Mar 05, 2018 10:33 am
Bear in mind that all wood can crack. Might be tension in the wood being released.
Are the fractures cross grain or with the grain?
PostPosted: Mon Mar 05, 2018 11:10 am
First name: Peter
Last Name: Norman
State: NL
With the grain...after I posted I went back to sand down the top. when flexing across the grain two more longer cracks opened up. figuring it must be a lot of soft grain.
I had thicknesses to 2.7 mm with a deflection at the intersection of the x brace of 6 mm using a 4 lbs weight.
I've got another YC tops but now am skeptical to use it...is this cracking/fracturing inherent with YC?
This is only my 5th guitar but have never experienced this with WRC, Sitka or Lutz in my other builds
Sent from my SM-J320W8 using Tapatalk
PostPosted: Mon Mar 05, 2018 6:53 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
I've never had any problem working with yellow cedar, seems to be a forgiving wood
PostPosted: Mon Mar 05, 2018 7:37 pm
I've used it on four guitars so far and never noticed a problem. It could be that the wood had some damage that is just now showing up. I usually try to give the soundboard cutoffs a good flex right after I cut them off to check for hidden flaws or bad glue joint, it gives me a little piece of mind that I'm not starting with an already bad piece.
Kent
These users thanked the author kjaffrey for the post: Peter Norman (Mon Mar 05, 2018 8:47 pm)
PostPosted: Mon Mar 05, 2018 8:51 pm
First name: Peter
Last Name: Norman
State: NL
Kent
I think you may be right about it being a bad piece. planed down the other YC top I have and seems to be much better. thanks
Users browsing this forum: No registered users and 44 guests
